#1 mechanical secondary jets?
hak Posted on: 2005/5/18 22:48
I am driving a 71, 510 wagon everyday that i
am slowly restoring. I heard the other day that there is a way to convert a 2 barrel carb who's secondary jet is actuated by vacuum to a mechanical acuation.Is this a "good mod? Does anyone know how to do this? The "garage" that knows of this is extremely exp$. I am on such a tight budget, that it's like having no budget at all.
thanks/hak
#2 Re: mechanical secondary jets?
creativepunka Posted on: 2005/5/19 9:52
well on my rotary it was just wired up or u can spot weld it. its not too hard. i dont no what your carb looks like but if you have a look u can work it out easly
#3 Re: mechanical secondary jets?
phunkdoktaspok Posted on: 2005/5/19 14:56
Yeah on Holley's we used to put a nut and bolt in the main throttle lever so that the secondries rod had a stop to hit against so it would be pushed open.
Only real benifit of it, is if your vac canister is stuffed.
You will probly find you will have a flat spot if you do it, but changing the position of the bolt will limit this flat spot.
#4 Re: mechanical secondary jets?
McBWagon Posted on: 2005/5/19 21:59
I fixed a holley to be a mechanical secondary by using a piece of garabge wire :P it worked great for me, gave the car alot more response when I 'floored' it, having a fair accelerator pump will almost entirely eliminate the flat spot if you decide to use this mod.
heres a pic
