Carb tuning
hey everyone, can anyone tell me what a good method is to correctly tune idle mixture screw and the slow idle screw, assuming the tuning on the two is way off?
the car is a 79 210 with an a14 in it.
Posted on: 2005/5/19 8:26
Re: Carb tuning
I would say that the best way to tune a stock A14's carb is with a vacuum guage & a tachometer. Fit the vacuum guage to a fitting on the inlet manifold, not the carb.
Adjust the engine speed to within factory specs, which is about 650 rpm if i remember rightly Next, while watching the vacuum guage, slowly turn the idle mixture screw. You are looking for an increase in revs & a stronger vacuum signal. If the revs pick up significantly, then reduce the idle speed & continue with the adjustment. You need to keep that idle speed down & work on geting that vacuum number up.
If the needle on the vacuum guage flickers too much, get some sort of clamp & gently squeeze the hose to the guage untill the flickering as adequately dampened. A fishtank airline clamp will often do the trick & try to clamp it near the manifold somewhere.
You know that you have it right when the engine idles smoothly at the correct idle speed & any movement of the idle mixture screw results in a reduced vacuum signal.
While you are doing all of this, make sure that the points are right & the timing is correctly set too. A correct idle speed will ensure that the timing can be set properly.
Posted on: 2005/5/19 10:14
Love your Datsun.
Treat it well.
Re: Carb tuning
From south australia
what should the timing be set to on an a series motor?
Posted on: 2005/5/19 13:16
Re: Carb tuning
From Strand, South Africa
10 degrees BTDC if memory serves me correctly(this is on an A14 don't know if the A-Series differ)
I don't have a timinglight so I usually just retart the timing until it stops to ping/knock. :-/
Posted on: 2005/5/19 13:42
Re: Carb tuning
Not too shy to talk
From Lismore, NSW
i was told by a reputable mechanic that my a12 runs best at about 12 deg advanced, not 22 deg advanced as the last owner had it set on
Posted on: 2005/5/20 4:14
