Re: super-charging a (a15 engine)
From WA
nino wrote:
Hi
Couple of questions to ask you datsun specific specialists, I am contemplating the idea of super-charging a (a15 engine). First things first I want to retain the push-rod style engine!!!!!!!!!
1. Who do I buy my engine components from? (Forged pistons, conrods, cam & other components required for the build.
you'll only need forged pistons, good moly rings and tri-metal style bearings. the std prepared (polished and linished - maybe cryo treated mains caps too) A series rods and crank will be up to the task. i'd get a fairly lumpy cam, as generally waht is good for an NA engine is good for a supercharged engine.
2. What compression ratio is enough for 10-15psi? (I would like to run at least 7.5:1) but I
Posted on: 2005/5/20 2:09
Subject Poster Date
     super-charging a (a15 engine) nino 2005/5/20 1:00
       Re: super-charging a (a15 engine) pro-240c 2005/5/20 2:09
         Re: super-charging a (a15 engine) 1200rallycar 2005/5/20 7:17
           Re: super-charging a (a15 engine) A14force 2005/5/20 7:48
             Re: super-charging a (a15 engine) nino 2005/5/20 8:48
               Re: super-charging a (a15 engine) tom210 2005/5/20 9:02
                 Re: super-charging a (a15 engine) nino 2005/5/20 9:15
                   Re: super-charging a (a15 engine) Freak 2005/5/20 9:46
                     Re: super-charging a (a15 engine) A14force 2005/5/21 0:51
                       Re: super-charging a (a15 engine) pro-240c 2005/5/23 3:34
                         Re: super-charging a (a15 engine) D 2005/5/23 9:40
                           Re: super-charging a (a15 engine) who_your_datty_1200 2005/5/23 10:12
