Re: a-14 or a-15 crank?
Not too shy to talk
From central vic, australia
The crank is still in the engine so i just stuck a tape measure down the bore with the crank at bdc then eyeballed accross the deck of the block. 220mm then did the same thing with the crank at tdc, 143mm.
220 minus 143 equals 77mm. what do you guys think about the pistons?
Posted on: 2005/5/24 10:45
Subject Poster Date
     a-14 or a-15 crank? turbo-b20 2005/5/22 12:12
       Re: a-14 or a-15 crank? Dodgeman 2005/5/22 12:27
         Re: a-14 or a-15 crank? Lemonhead 2005/5/23 10:05
           Re: a-14 or a-15 crank? turbo-b20 2005/5/23 10:39
           Re: a-14 or a-15 crank? Dodgeman 2005/5/23 11:27
             Re: a-14 or a-15 crank? turbo-b20 2005/5/23 11:42
               Re: a-14 or a-15 crank? Lemonhead 2005/5/23 13:02
                 Re: a-14 or a-15 crank? turbo-b20 2005/5/24 10:45
