Broken Fuel gauge
Hi guys, I just purchased a granny spec 1200 sedan and the fuel gauge is not working.Could please help me out.I will post some pictures of the car later on Thanks crystal
Posted on: 2005/5/29 8:13
Re: Broken Fuel gauge
could be the sender in the tank or the wiring to the dash.... as long as it has peterol in it... and the temp guage works your ok!
Posted on: 2005/5/29 9:45
yeah the temp gauge is fine although I had to fiddle with the wires under the dash to fix it properly. Still not sure about the fuel gauge, as long is it goes for now i'm happy.
Posted on: 2005/5/29 11:52
g'day and sweet looking sedan....nice to see another one still going strong
had/have the same problem in mine, you might find the little thin wire on the actual fuel float in the tank has broken if it's not in the wiring somewhere
once you've run out of fuel 2 or 3 times you'll be kicking yourself .... i've still got the 10l jerry can in the boot just in case
Posted on: 2005/5/29 12:34
