Disc brakes for 1200 ute
Not too shy to talk
I have ann almost standard B120 ute which I quite often overload to around a ton or so. Disc brakes seem like a good idea. What's the best set to use for the least amount of mucking around?
Posted on: 2005/5/29 1:03
Re: Disc brakes for 1200 ute
From Launceston, Tasmania
hi
Your best bet, would be to fit 120y disc brakes, or try and find dics brakes from a 1200 coupe.
This is the most simplist and cheapest way to upgrade to a disc front end for a 1200 ute.
Hope I was of some help
Bye for now.
Posted on: 2005/5/29 7:30
From Newscastle, Australia
I reckon youd need to go with stanza with semi metallics ...you are hauling 1.7 tonnes around youd want the best brakes you can whilst keeping your std wheels...
Posted on: 2005/5/29 8:38
Dont die wondering.....
From Adelaide, South Australia
A ton, god dam.
Posted on: 2005/5/29 14:49
"Anyone who has never made a mistake has never tried anything new"
Albert Einstein
Put stupid oversized photo here>>
From perth
hey i just fitted stanza struts to the front of mi datto nd the went in soo easy get hold of some and put them in it will be easy to put a booster in good luck anyway.
Posted on: 2005/5/29 15:19
Not too shy to talk
So there is no problem with the front sitting too high (with the struts from either a stanza or 120Y)?
Posted on: 2005/5/31 0:09
From Melbourne, Australia
there wont be height problem with 120y, but with stanza struts you need a lowered spring to bring it back down to earth
stanza strut being the one from square head light stanzas only, the round headlight version has a diffrent incompatible strut
Posted on: 2005/5/31 4:33
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Not too shy to talk
Thanks for everyone's help.
Posted on: 2005/5/31 6:34
From Sunnybank, Brisbane
just did the stanza conversion as well, went in ok afta a bit of work with the die grinder, thinkin maybe i got the square headlight version mentioned b4, chucked on the standard 1200 springs, and the bastard sits way lower than b4, think its cos the old struts i got were a bit hows ya mother, only real problem i got is the camber is rooted, ive heard sumthin bout 120y casters and swaybar wats the deal??? stoping kicks arse, i really need a CA
Posted on: 2005/5/31 10:06
From perth
hey yeh the stanza struts are about another 20mm higher not much really but noticably higher with the stanza springs...gota get around to changing them
Posted on: 2005/5/31 13:13
