Re: Hype around the Side DRaughts true ?
From Wellington New Zealand
Fit the sidiedraughts mate.....you will want to fit extractors/headers at the same time cause you rarely get an inlet manifold to clear the standard exhaust manifold. To really make use of the carbs you should fit a new performance cam and you will be pleased with the transformation . As for the story about about Webers being no longer available that is complete horse ####. Weber sold the manufacturing rights and they are now made in Mexico. DCOE and IDAs are still available new in all the popular sizes.
Posted on: 2005/6/6 1:23
1200 coupe 1400 GX 5 speed
1200 coupe LHD peripheral port 12A rotary.
1200 ute
Sunny 310 SGX.
I am also pretty sure that a bog stock Aseries will not even run with twin carbies, the cam is not large enough.. maybe SU's tuned down alot but not Webers, could i be wrong?
Now c'mon, you should know this because your Webers came off a stock A15.
My A15 was running a stock carby and a set of extractors. When I fitted the twin 40's there was a huge difference in power and response. It was definately worth the money.
I don't think you'll be using sidedraughts to their full potential unless you build the motor, but they are still worth putting on a stock motor.
Posted on: 2005/6/6 6:07
Datsun 1000 ute - Building (slowly)
Datsun 1600 13B turbo - coming soon
Yes the rights were sold some time ago, some carbies were produced but from what I have heard they also stopped manufacturing about 12 months ago.
By the way, if anyone is seriously looking for a pair of 45 DCOE's I have some I may consider parting company with for the right price.
Posted on: 2005/6/6 10:45
From Stray-ya
So 40's are worthwhile if the motor is built and still give a noticeable bit extra on a stockie..... But is it worth the extra money over a 32/36 downdraught?...... or a set of SU's??
I've got a pair of 1.5 in SU's on an L series manifold, but they need a full recond- I'm trying to decide if its worth the effort to sort them out and find/ fabricate a manifold for them. The engine is an A-15 with mild cam extractors & lightened fly & stock carby..... goes alright but not great, still takes about 10 sec to get to 100
Posted on: 2005/6/6 11:16
« 1 (2)
