Re: Disc brakes for 1200 ute
Not too shy to talk
I picked up some struts from a sunny which looked about right except that in trying to fit them I find the bolt holes on the bottom are at 80mm centres whereas the old ones are at 75mm centres. Should I just elongate the holes in the struts so they line up?
Posted on: 2005/6/4 11:10
From sydney australia
no,you need to get the lower control arm,ball joint,& steering arm from the sunny.or stanza if you can't get sunny.
Posted on: 2005/6/4 13:18
Not too shy to talk
I couldn't be bothered going back to pick-a-part to get the extra bits so I tried elongating the holes in the struts. It took about an hour of filing to get them right. They went in OK and the car drives well. It does sit about 20mm higher but this is not a bad thing as I sometimes carry long lengths of timber (7.2m is my record) and the extra travel will come in handy.
Posted on: 2005/6/6 3:29
From perth
hey did you notice you had another couple of degrees of positive camber or is it just me?
Posted on: 2005/6/6 11:31
Not too shy to talk
It might just be you as everything seems fine to me.
Posted on: 2005/6/9 3:15
« 1 (2)
