Need some help
hey guys i have a dastun 1200 sedan that was recently involved in an accident which left the front of the car severly damaged. My question to anybody is which front can i use as a replacement for mine as i have been unable to locate any more sedan models. i live in jamaica and the only datsun's i have seen are b210's and 120y's so my options are limited.
Posted on: 2002/8/9 21:36
Re: Need some help
From Stone Age somewhere in U.S.A.
unfortunatly, the answer is that only 1200 parts will fit with out major work.
check your local body shops for one that has the capability to straighten unibody vehicles.
what this entails is clamping the body down at the rocker panel pinch welds and using a hydralic ram to pull things back into shape. unless there is real major damage, an experianced shop should be able to repair what you have, how much it will cost will depend on them.
good luck
Posted on: 2002/8/10 4:45
