« 1 (2)
Re: how to increase performance of A12. Sunny B310
From Central Vic
We have heaps of A15 heads laying around none of them are swirl design??????????????
they flow heaps more then A12 standard head
the swirl design A15s i have never seen so hunt around and check the ports
Posted on: 2005/6/10 7:44
Not too shy to talk
From A
Would the a15 head cause a compression loss on the a12?
Posted on: 2005/6/10 14:30
From California
Well the problem with this thread is that the Maz HASN'T FILLED IN HIS LOCATION
Swirl port heads may be exclusive to U.S.
If you're in Pakistan, you may not even get the A15.
Posted on: 2005/6/10 18:48
From Townsville, Qld
Having a read through the tech sections and old post here and I have a question. What do you think about using a standard A15 exhaust manifold on the a12 head with a 32\36 webber? It's already on there but I want to know if it's worth the "budget" to get a 1 3/4 inch pipe mated up to it with plans to uprage it later.
manifold
Posted on: 2006/4/10 6:39
with your exhaust, if you can get a new flange that suits the orig manifold, upsize the main engine pipe to 2" with a single sports muffler. if you cant get a new flange have the exhaust cut a couple inches below the orig flange and go from there, the A series engines love to have lots of air go in and out the faster you can get this happening the faster you can get the engine to go.
even with the stock carby you'll notice a big improvement in the rev range
Posted on: 2006/4/10 9:47
Thats a good idea. thanks for that
Posted on: 2006/4/10 11:20
« 1 (2)
