Re: Which cars have you sourced bits from???
From Perth WA
don't worry about the purists, Ford 9" diffs are under nearly every make of car under the sun... same with Holden Powerglide transmissions...
i've got the following manufacturers in my car...
oh yeah, i don't have a car!
Posted on: 2005/6/13 12:38
- sidewayz.cjb.net -
Subject Poster Date
     Which cars have you sourced bits from??? 1200rallycar 2005/6/13 12:08
       Re: Which cars have you sourced bits from??? dattodude 2005/6/13 12:15
         Re: Which cars have you sourced bits from??? Dodgeman 2005/6/13 12:32
           Re: Which cars have you sourced bits from??? SunnysRule 2005/6/13 12:38
             Re: Which cars have you sourced bits from??? ANGE 2005/6/13 12:54
       Re: Which cars have you sourced bits from??? Dattogal 2005/6/13 12:55
         Re: Which cars have you sourced bits from??? matty 2005/6/13 13:17
       Re: Which cars have you sourced bits from??? tom210 2005/6/13 15:12
         Re: Which cars have you sourced bits from??? converted 2005/6/13 15:14
           Re: Which cars have you sourced bits from??? AFRacer 2005/6/13 15:52
             Re: Which cars have you sourced bits from??? dazzasute 2005/6/13 16:54
               Re: Which cars have you sourced bits from??? tappet 2005/6/14 0:35
                 Re: Which cars have you sourced bits from??? vex66 2005/6/14 13:36
                   Re: Which cars have you sourced bits from??? dazzasute 2005/6/14 13:47
                     Re: Which cars have you sourced bits from??? vex66 2005/6/14 14:14
                       Re: Which cars have you sourced bits from??? _steve_ 2005/6/14 14:26
                       Re: Which cars have you sourced bits from??? _steve_ 2005/6/14 14:27
       Re: Which cars have you sourced bits from??? ade 2005/6/14 23:52
         Re: Which cars have you sourced bits from??? Coops 2005/6/15 1:18
           Re: Which cars have you sourced bits from??? cl 2005/6/15 1:53
             Re: Which cars have you sourced bits from??? D 2005/6/15 2:54
               Re: Which cars have you sourced bits from??? L18_B110 2005/6/15 3:13
                 Re: Which cars have you sourced bits from??? Dodgeman 2005/6/15 3:19
                   Re: Which cars have you sourced bits from??? L18_B110 2005/6/15 3:45
                 Re: Which cars have you sourced bits from??? pro-240c 2005/6/15 3:21
