« 1 (2) 3 »
Re: Which cars have you sourced bits from???
From Perth Western Australia
so far all the bits i've used are datsun/nissan...
120y suspension/diff
200b engine/tailshaft
stanza 5spd box
wagon grill/chrome trims
and there's a few micellaneous ones such as westroof colourbond sheet metal in the back of the cab and fielders sheet metal for that bit below the tailgate
Posted on: 2005/6/13 16:54
From Brissy
i thought i might join the wagon
nissan silvia sr20det motor, gearbox, clutch master cylinder , cpu , instrument cluster
nissan r32 gtr radiator..
series 3 bluebird front struts, fulcrums coil overs.
vl commodore strut inserts, bearing plates.
vl turbo disc brakes, lsd disc brake diff, handbrake setup.
toyota hilux rear shocks.
datsun 180 brake booster and master cylinder....
Posted on: 2005/6/14 0:35
From Brisbane, Australia
What about motorbike parts? They make some excellent side mirrors & petrol caps. Maybe some of their gauges? I was told by a mate who is an engineer by trade that they put a motorbike engine & gearbox in a Mazda 1000 ute & ran chain drive. It got me thinking. Apparently they even got it approved as their was no rule saying you must have reverse. They all forgot about that.
Posted on: 2005/6/14 13:36
there was a post on here a while back about a mini in england that had the whole rear end chopped out, and they put a road bike engine in it. rear wheel drive and all, and it went hard.
about the no reverse, maybe you could adapt something from a 4 wheeler? some of those have reverse.
just make sure you upgrade the clutch!
Posted on: 2005/6/14 13:47
Yeah, I did a bit of internet research for fun. Some bikes have an electric reverse & one guy used a flywheel & starter motor. If I got serious, the first thing I would do is contact a trike manufacturer as the technology should be similar. I also thought about a shaft driven bike as a donor.
Posted on: 2005/6/14 14:14
From Melbourne, Australia
Posted on: 2005/6/14 14:26
When the going gets tough the Datsun keeps going😋
vy hsv gts door skin 2 fix rust
mazda 121 seats
nissan n10 a14 eng
ford 32/36 waber
bmw rims 16s
that is all 4 now
Posted on: 2005/6/14 14:27
From Brisbane Australia
I have sourced bits for my resto from every 1200 model, ute diff,coupe brakes,coupe seats,every possible option from everycar.
I was lucky that when I started there were quite a few 1200's to buy and wreck.
My list is 1 wagon,3 utes,1 coupe,1 other 2 door sedan and 1 sedan.
As I worked in Honda parts I have heaps of honda bolts,clips,bulbs,dizzy parts etc etc
Posted on: 2005/6/14 23:52
From Bris-Vegas
Clutch Pedal assembly, Fuel tank, Wheels, Rear Brakes & Diff - R31 Skyline.
Radiator - SR20 (200sx)
Engine, Gearbox & Front Brakes - S13 Silvia (CA18DET)
Front Struts - 120Y
Clutch Master Cylinder - Nissan Patrol
Brake Master Cylinder & Booster - Nissan Pulsar
Posted on: 2005/6/15 1:18
CA18DET '74 1200 ute project
Not too shy to talk
Valiant (I think). I made a removable tipping tray for my ute. The tipping action is provided by 2 valiant jack shafts welded together with a single ratchet jack mechanism. In the original use, the jack would hook up under the wheel arch.
Posted on: 2005/6/15 1:53
« 1 (2) 3 »
