Complete, but stripped down z18T & Gearbox. Details as follows:
Head has been rebuild and slightly ported, Still in brand new condition in the plastic after coming back from the machine shop Cost $700 just for the head rebuild. (See Pic Below)
2mm oversize pistons, Copper Head gasket. The block and pistons have been measured and are well within their acceptable limits to putback together. Will need only new bearing I guess and a gasket kit.
Modified Intake Manifold by plazaman to accept 65mm throttle body, Custom fuel rail and FJ20T injectors and XF 65mm throttle body.
Standard Turbo with minimal shaft play and as mentioned above z18T 5 speed.
As far as I know everthing is here, sump, dizzy, head bolts, flywheel, clutch (Needs new one though) etc etc.
I'm after $800 for the lot, thoughI would defintely consider a swap/trade for an 280zx L28 motor with cash adjustment either way depending on condition. Any questions don't hestitate to ask.
