coupe twist?
Quite a regular
From Adelaide
building 1200 coupe with 13b turbo,(yeah i know MAZDA in datto!)aiming for 9s but want to keep the car as streetable as possible. i know of a few drag cars running 7s and 8s but all seem to use rollcage. i know this is a good option to strenghten up the whole car but is there another streetable option like chassis rails or something? thanks for your help.
Posted on: 2005/6/21 10:22
Re: coupe twist?
From Brisbane, Narangba
ANDRA rules say that if you run quicker than 10.99 i believe you need a full cage, harness ect.
Posted on: 2005/6/21 10:44
Re: coupe twist?
Quite a regular
From Adelaide
yeah i know but adelaide isnt andra owned and run.until it is i wont be running a cage.
Posted on: 2005/6/21 11:20
Re: coupe twist?
From Newscastle, Australia
I can sell you a twisted coupe which would twist the opposite way to your torque and all would be OK!!!
Posted on: 2005/6/21 11:56
Dont die wondering.....
Re: coupe twist?
I think youll find the rules still apply. Anyway in a 1200 running 9sec quarters at over 160mph I think I would like a cage. I mean if you hit the wall life is over at that point. 1200s are made from recycled coke cans you know.
Posted on: 2005/6/21 11:59
Re: coupe twist?
Converted just brace it now your reckon, so when its under full load its dead straight. I bet there are draggers out there that actually use that principal.
Re: coupe twist?
From Warwick, QLD
yeah anything running sub 11sec 1/4 miles need to be caged as the raceway will say go home and don't come back without a cage and they won't let you race without one. I got that off a discussion on the cruising brisbane forums
Cheers
damo
Posted on: 2005/6/21 12:22
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
Re: coupe twist?
From Sydney Australia
Yes Wayne strengthening the body from under the car like chassis rails ect can be done and is a good option if ya dont wont the po po pulling you over every time they see your cage, but its not as strong as a cage and is quite expensive and weighty (I just made up that word)
Posted on: 2005/6/21 13:55
Currently own a 73 1200 with sr20de and a 71 1200 with almost finished a14 blow through
Re: coupe twist?
From Arlington, TX, USA
Is that common in Oz? Never got stopped for my cage here in the states...
You didn't make up the word.
weighty
adjective: Having considerable weight; heavy.
Posted on: 2005/6/22 2:08
1973 Datsun B110 Coupe (A15/5spd)
1977 Datsun 280Zed (5.0L/5spd)
Re: coupe twist?
From Sydney
Wouldn't you consider a cage anyway? Is your life important to you? What if you crash at speed?..........Just food for thought.
Posted on: 2005/6/22 2:14
