« 1 2 3 (4) 5 6 7 »
Re: and unicorns and other mythical creatures...
From Bridgetown, Barbados. W.I
How long do you want it to last ?
A full racing season.......which will be no more than about 20-24 hrs, all out.
And once in a while a regular drive on weekends.
i asked that question because the rod ratio of that engine is really low. 1.5 or sumtin so.
Posted on: 2005/6/21 13:53
Life's better SIDEWAYS!!
From Adelaide, South Australia
You should be fine with 7000 or 7500.
Posted on: 2005/6/21 15:27
"Anyone who has never made a mistake has never tried anything new"
Albert Einstein
Put stupid oversized photo here>>
What are the regs on engines in this class ?
Posted on: 2005/6/21 15:30
Albert Einstein
engines from 1800cc to 2000cc? Standard cylinder blocks must be used(i.e no aftermarket alloy blocks etc)
everything else if free.
Posted on: 2005/6/21 17:27
was cleaning and found some 35mm exhaust valves i had 4 my fiat TC engine but they are 4.25" compared to the Lseries 4.57" in lenght.
Is there anyway i can get these to work in the Lseries head.
ps.They fit into the valve quides correctly too.
Posted on: 2005/6/22 16:03
What about regs on fuel ?
Posted on: 2005/6/22 18:18
Albert Einstein
anything goes really......dont think u can use methanol tho.
Posted on: 2005/6/22 18:42
Anymore tips/trick on tuning this engine????
Posted on: 2005/6/25 0:31
From Toowoomba, australia
l20 block, z24rods, z20pistons, l20 head ported valves double valvesprings cam depends on valve sizes. twin 48 or mechanical injection
cant go wrong
Posted on: 2005/6/25 1:10
why go up and down when you can go round and round
THis will still keep it under 2000cc rite???
Will the Jetronic system, be to Restrictive???
If not that would be great cause i have, a complete Jetronic System Already.
Jus gotta grind off the manufacturer
Posted on: 2005/6/25 2:49
« 1 2 3 (4) 5 6 7 »
