Transmission swap
Not too shy to talk
From Grapeview, WA.
What transmission could I use one my A15. When I went to the track my 2nd to 3rd was killing me. The revs droped way to much. Are there any swaps I could do? I live in WA. USA. I need something that has closer ratios. Any help would be greatly appreciated. Thanks
Posted on: 2005/6/22 15:20
Re: Transmission swap
From Invercargill, New Zealand
I am presuming that you have a 60A 4 speed in there right now. If that is the case then look for a 63A 5 speed out of the same model 210 that you have. A better option ratio-wise is an alloy case toyota box. You can select a wide range of ratios from TRD but the standard ones are ok. You are running the quarter mile right? Could also consider a rear end ratio drop if you don't drive the car on the street much.
Posted on: 2005/6/22 16:38
