« 1 (2) 3 4 5 ... 8 »
Re: How do i get 200hp from an A14
From Cairns, Far North QLD
Insert a 13B turbo, job done.
Ray
Posted on: 2005/6/23 10:16
From Christchurch NZ
If you have the fuel injection manifold, then the rest is all plain sailing.
Get a sensibley sized turbo, and build a water to air intercooler. Use the biggest valves you can fit. Pay someone with a good rep to do the biggest port job they can. Get some forged pistons. Have your conrods polished, balanced and shot peened. And cryogenicly annealed. Get aftermarket rod bolts and head studs. Use roller rockers. Have everything blueprinted. Use fangled coatings for the inside of the chambers etc. Underdrive the alternater. knife edge the crank, as well as having it shot peeened and cryogenicly annealled. Cryogenicly anneal all motor parts. run the biggest exhuast that will fit under the car, with the least restrictive mufler you can find. Stick a dual stage nitrous oxide kit on with eight fogger nozzles.Use rings that are real thin for less cylinder wall drag.
And spend more money than I make in a year.
Did I miss anything?
Posted on: 2005/6/23 10:31
Forced Induction!
From WA
Ray
or just a stock port RX4 13B with a weber, elec dizzy and exhaust - that's 200hp right there.
god i love rotors...
Posted on: 2005/6/23 10:35
From Townsville NQ
A14force - have you ever dynoed your rig?
Posted on: 2005/6/23 12:21
MattoRX7 wrote:
i need to get 200-250hp out of an a14
Someone once told me that to get this kind of power from a little pushrod four cylinder engine that was originally designed to be an economy engine, you need a balance beam scale.
Into the dish on one side, you place your engine. To balance it up, you start to stack $20 bills on the other side. When it's all nicely balanced, you take the engine, & the money, to the best engine builder in the country, then wait for his phone call.
Now, i don't know how true that is, but then again, maybee they should be $50 bills.
I guess it can be done, but engine reliability & expected life span decreases almost exponentially once the power figure rises above a certain point. Do words like 'Methanol' or 'Nitro methane' strike a familiar note?
Posted on: 2005/6/23 14:03
Love your Datsun.
Treat it well.
From brisbane
I was under the impression that rotary turbos weren't much chop on piston motors due to the vastly different exhaust pulsing. Is that the case?
Your bank account and sanity will thank you if you fit a CA18DET or SR20DET. Either of these motors can reach 250rwhp reasonably cheaply and reliably.
Regards Matty
Posted on: 2005/6/23 14:14
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
From Central Vic
Steady on peoples
If you can do alot of research and planning and work yourself there is no reason you cant get great power out of the little Aseries
with No thought no planing and no work you will build yourself a handgrenage
but dad used to race agaist a sunny with an A15 20 years ago that had nearly 300hp with T03 and a carby
It all come's down to compresion fuel and boost and a massive head port
If they raced A15's NA with 180hp why not 250 with boost
Posted on: 2005/6/23 15:02
From Adelaide, Australia
i didnt want sooooo many people replying crap. i am serious! i ca only use an A14 so if i get defected i can just ake the turbo off and get it of defect. if people are getting 160-180hp with twin webbers and non turbo then 200hp is very reachable. as if a T3 turbo with injection n stuff cant make me 200hp but i just need info of people who have done tis so i dont waste time and moey on mistakes. that shaun guy how can i contact him about his motor? how much power is he pulling with a turbo'd gassed A series
Posted on: 2005/6/24 1:15
Why are you restricted to an A14?
Posted on: 2005/6/24 2:29
From Canada
Umm... ya... Why do you HAVE to stick to an A14 ? and Why 200+hp.
Is it some kind of bet or something? The A14 wasnt stock anyhow, we really are curious
Posted on: 2005/6/24 2:39
