Re: How do i get 200hp from an A14
From Invercargill, New Zealand
Yes killer1200 - where did you get your 180 hp figure from??? Neil's motor dynoed at 98.7hp - a very impressive result but still shy of your claimed amount. The best recent dyno I know of was for a schmick as build A15 big block on 50 mm throttle bodies and it made 120 hp at the wheels. I love what the internet does for hp claims....
Posted on: 2005/6/25 3:39
I believe that this kind of power output can be achieved. The secret ingredients would include lots of nitro methane & lots of boost. Unfortunately, engine life expectancy would be compromised.
You could call this engine the M36 as it would very likely have both the life expectancy & performance of the hand grenade it was named after.
It's all a matter of balance & trade off. As power goes up, so does the cost [exponentionally?] & conversely, service life comes down,... a lot.
Posted on: 2005/6/25 9:50
Love your Datsun.
Treat it well.
From Mudgee NSW Australia
Why spend heaps on big carbs cams engine work ect!! I would leave it stock fit two turbonator Zet fans and 100hp NOS easy 200hp at the wheels !!!! Might have to improve the exhuast and filter. A 4 inch crome tip would also improve top end maybe 220-250 hp at the wheels and low 9 second passes on street tyres easily acheiveble.
Would be fully sick mate
Posted on: 2005/6/25 12:06
If In doubt run more BOOST
From brisbane
Nissan4ever - mate I've never seen a 1000cc 4AGE let alone one that puts out 400 - 600hp
Posted on: 2005/6/25 13:36
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
From Bridgetown, Barbados. W.I
hold on a minute i'll find the link
999cc 4age
Posted on: 2005/6/25 15:22
Life's better SIDEWAYS!!
That mr2 is an interesting read
Posted on: 2005/6/25 15:59
From Christchurch NZ
Ash wrote:
A14force - have you ever dynoed your rig?
No. Unfortunately the motor devoped some "issues" before I had the chance.
Once I get my new motor together, I'll be taking it to the dyno for sure.
Posted on: 2005/6/25 23:34
Forced Induction!
From Taupo New Zealand
Traction would probably be a problem with so much power in a light car so you'd need at least a Ford 9" diff and fill the boot with as many subs and amps as you can, in fact better base it on the wagon so you can fit more in the back to keep a bit more weight over the rear axle. With this setup I see no reason why high eights wouldn't be easily achievable.
Posted on: 2005/6/26 11:02
1970 1200 coupe A15
1972 1600 original except for nana's sheepskins
1978 B310 SR16VE
ca18det_man wrote:
I would leave it stock fit two turbonator Zet fans...
Death Wish
Posted on: 2005/6/26 13:29
From Townsville NQ
by teretonga on 2005/6/25 13:39:44
So a well sorted carbed motor can get 100hp (close enough) at the wheels, say 130hp crank? Who says 200+ with boost is impossible?
Posted on: 2005/6/26 13:31
« 1 2 3 (4) 5 6 7 8 »
