Flaring guards
From Brisbane
Hey guys, i was just wondering how much it costs to flare your guards, cause my wheels dont fit under them and its chewing away the rubber... any help is appreciated..cheers
Posted on: 2005/6/27 11:47
Re: Flaring guards
From Melbourne AUS
any good suspension specialist will have a flaring tool to do the job properly...
i got the lip of my front guards rolled and the guards flared for $50...
guards then required painting as i had minor cracks on the edge of the lip.. and plus i also had to trim a small bit from the bottom corner (in front of the wheel)
it can be done with other methods but you generally end up with filler to get the guards straight again...
good luck
heres a pic of the outcome
Posted on: 2005/6/27 12:01
1973 B110 A12
Re: Flaring guards
From Sydney, Australia
Ange your front end is sooo straight.
I'm very envious. I sometimes wished I'd started with anything other than a rolling shell.
Nissan had some fairly poor quality control on a lot of their parts. It's almost always better to use the same panels as were fitted when it rolled off the line.
I'm about to cut a bit from the front off my guards, I'm tired of the rubbing..damn 15x6 wheels with 185/195 tyres just don't fit on a 1200.
Awesome photo.
Chris
Posted on: 2005/6/27 14:18
Re: Flaring guards
From Melbourne AUS
nah your right.... they dont fit on the front...
with the mods ive got mine down to minimal rubbing mainly on the inner (footwell) guard at full lock...
the things we do....
im on 195/50's....
had a hard time finding decent 45's that were justified for the price.... so took a gamble with the 50's and am living with a bit of rub here and there
my ute has had replacement guards and bonnet... it is pretty straight... but they always look better in a digi photo
no need to be envious
Posted on: 2005/6/27 14:29
1973 B110 A12
Re: Flaring guards
From Brisbane
Thanks for that ange, have to go and check that out, hope it all works out good. Love the look of your ute!!
Posted on: 2005/6/28 0:40
Re: Flaring guards
From Central Vic
I had 20mm turned of the end of my castor bars this aided handeling and helped with the rear scraping then I simply ran pipe around the gaurd in various sizes to gain my flare
rough but good for club days
To do this i just squezzed the pipe between the gaurd and tyre and rolled the car back and forth til i had the required flar
no good if you want pannels that straight though
oh i also cut quite abit off the bottom frount corner
Posted on: 2005/6/28 0:44
