Re: SR20DE
From Christchurch, New Zealand
would help if i knew wtf that was!
Posted on: 2005/6/29 9:00
Re: SR20DE
A tray/rear mounted big block 454 mwahahahaha
What about sourcing the V8's they used in the presidentials??
KA24DE?? Ive heard bad stories about these engines but built right im sure it'd be fine....
Or the ####y VG series!!
some food for though!
Dave
Posted on: 2005/6/29 9:03
Re: SR20DE
From Christchurch. NZ
Well an engine for your car, that isn't so widely done??? How about a GA16 they look quite nice in the engine bay and would go well in a datto. If you want some power I am sure a VG30 would fit in there as they engine bay on the sunny must be a bit bigger than the 1200.
The parts that I need are:
Thermostat housing
Block to head Dowels
A15 Dipstick and Tube
Waterpump pulley
Block coolant intake pipe with single heater pipe
Re: SR20DE
Im not really after a engine that will make the car quick, im planning on a building a car that is auto, no bigger than 2.5L and have decided has to be a 6 cylinder, and carby not efi. An engine i have considered strongly is a 2.3L out of a ford grandia, you european boys should be familar with them, the engine itself is german built, from block up to carby, they produce around 120hp, only problem is parts arent exactly easy to come accross. my friend has 2 of these motors, one in bits, one complete that is in extremly good condition, it was in a escort but now it has a 2lt pinto.
Karl
Posted on: 2005/6/29 10:20
Re: SR20DE
From Stray-ya
I'm scratching my head here..... If you're only chasing 120 hp why bother with the hassle of a six? there's plenty of budget fours that will develop those kind of numbers, and very few sixes that are that gutless......
BTW: Mitsu MIVEC is a revvy four that I just researched for a conversion- plenty of detail if you search the posts, difficult conversion tho
Posted on: 2005/6/29 11:02
Re: SR20DE
put a GA engine in then, you'll love it. Do they come out in a RWD config?
Posted on: 2005/6/29 11:50
Re: SR20DE
or pic one
Manuf. Engine Type CAR MODEL & DESCRIPTION YEAR SIZE
A14 210, RWD '81-82 1.4 L
A15 210, RWD '81 1.5 L
L20B 200SX/510/610/710/PICKUP620,720,Overhauled ~'77-80 2.0 L
Z20 200SX, EFI, ALUMINUM VALVE COVER '80-81 2.0 L
CA20 200SX, EFI, RWD, Side/front distributor '84-88 2.0 L
GA16DE 200SX, DOHC, 16V,timing chain '95-98 1.6 L
SR20DE 200SX, FWD, DOHC, 16V '95-98 2.0 L
KA24E 240SX, RWD, 12V '89-90 2.4 L
KA24DE 240SX, RWD, DOHC, 16V '91-95 2.4 L
L26 260Z '74-75 2.6 L
VG30I 300ZX, RWD '85-88 3.0 L
VG30T 300ZX, TURBO, RWD, 4 BOLTS '84-89 3.0 L
VG30DE 300ZX, RWD, DOHC, 24V '90-95 3.0 L
VG30DETT 300ZX, TWIN TURBO,RWD, DOHC, 24V '90-95 3.0 L
A15 310, RWD '81 1.5 L
E15 310, CARB, SOHC, 8V '82 1.5 L
Z20 510, CARB '80-81 2.0 L
KA24DE ALTIMA, FWD, DOHC, 16V '93-02 2.4 L
KA24E AXXESS, VAN, FWD, 12V '90-91 2.4 L
VG30I MAXIMA, FWD, 4bolts '85-88 3.0 L
VG30E MAXIMA, FWD, SOHC, 12V '89-94 3.0 L
VE30DE MAXIMA, FWD, DOHC '92-94 3.0 L
VQ30DE MAXIMA, DOHC, 24V, V6 '95-97 3.0 L
GA16DE NX1600, DOHC, 16V,timing chain '91-94 1.6 L
SR20DE NX2000, FWD, DOHC, 16V '95-98 2.0 L
Z24 PATHFINDER, RWD, Recondition engine '87-89 2.4 L
VG30I PATHFINDER, 4X4 '87-89 3.0 L
VG30E PATHFINDER, 4X4, RWD '90-95 3.0 L
VG33E PATHFINDER '96-6/99 3.3 L
Z24 PICKUP 720, Recondition engine '83-85 2.4 L
Z24 PICKUP HARDBODY, Recondition engine '86-89 2.4 L
KA24E PICKUP, RWD, 12V '90-95 2.4 L
VG30E PICKUP, 4X4, RWD '90-95 3.0 L
E15-S PULSAR, SOHC, 8V, Timing belt '83-86/'87-88 1.5 L
E15-T PULSAR, TURBO, SOHC, 8V '83-84 1.5 L
CA16DE PULSAR COUPE, DOHC, 16V '87 1.6 L
CA18DE PULSAR, DOHC, 16V '88-89 1.8 L
GA15I PULSAR, SOHC, 12V, Replace GA16I '89-90 1.5 L
VG30E QUEST '93-95 3.0 L
VG33E QUEST '99 3.3 L
E15-S SENTRA, SOHC, 8V, Timing belt '81-85/'86-88 1.5 L
GA15I SENTRA, SOHC, 12V, Replace GA16I '89-90 1.5 L
GA16DE SENTRA, DOHC, 16V,timing chain '91-94/'95-99 1.6 L
SR20DE SENTRA, FWD, DOHC, 16V '91-94/'98-99 2.0 L
CA20 STANZA, FWD '82-89 2.0 L
KA24E STANZA, FWD, 12V '90-93 2.4 L
Z24 VAN, Recondition engine '87-89 2.4 L
VG33E XTERRA '99 3.3 L
Posted on: 2005/6/29 12:02
Re: SR20DE
From Brissy
honda s2000 motor.. 2l NA rwd... im pretty sure they've got 200 kw at the fly
Posted on: 2005/6/29 14:18
Re: SR20DE
s2000 motor would be mint, buttttttt availability and expense for one is the factor. . . and the fact its out of a *cough* honda. im going for a ford v6, simply because they are a great lil v6, produce a good amount of torque and are strong!.....and because no one else has ever done the conversion on a datto. im not after a ultra quick setup, im after a setup that will be good for cruising, sound good and be --unique--. will be picking up both motors in the weekend. why??. because I can, if your going to crititise any motor or person, go start on those idiots who destroys datsuns by putting wankels in theirs.
Posted on: 2005/6/30 10:22
« 1 2 (3)
