(1) 2 3 »
#1 how to combat axel trample
low1000 Posted on: 2005/6/30 5:52
Any ideas about how to get around this foe without going down the tramp-rod route.
thanks
Elliott
#2 Re: how to combat axel trample
shaun Posted on: 2005/6/30 6:08
apparently the bloke who owns pedders in penrith and his brother have made and sell a set of leaf springs that are 2 inches lower than standard and they also stop axles tramp
he sells them at pedders for around 350 a set i think
go talk to him great bloke cant stop him talking after you tell him you own a 1200
#3 Re: how to combat axel trample
ddgonzal Posted on: 2005/6/30 6:22
Put the A10 back in? Sorry I just couldn't resist.
#4 Re: how to combat axel trample
L18_B110 Posted on: 2005/6/30 6:52
first of all, check the condition of your shocks...
then take out your lowering blocks :P
otherwise fit a reversed half leaf on top of the front half of the spring pack. I used a cut off 120Y main leaf.
#5 Re: how to combat axel trample
DVLDAT Posted on: 2005/6/30 10:08
um only thing that will fix axel tramp properly is a set of CAL TRACS
#6 Re: how to combat axel trample
converted Posted on: 2005/6/30 11:53
Nope the springs I got from John Taylor were perfect for solving axle tramp..well worth the money spent. Dont even need to consider tramp rods.
CA18DET_MAN would also attest to that these springs working well with 206rwkw and no tramp...
#7 Re: how to combat axel trample
ca18det_man Posted on: 2005/6/30 12:05
No tramp for me with JT rear springs 5000rpm 20psi 2nd gear launches but wheelspin still a bit of a problem migth have to run some more boost
#8 Re: how to combat axel trample
Mr_Turbo Posted on: 2005/6/30 14:47
im gettin tramp bad the other day the wheels came off the ground got a hell of a jolt! my left shock ir rooted tho. more info on these leafs?
#9 Re: how to combat axel trample
sidedraught Posted on: 2005/6/30 22:14
Ring Pedders at Penrith thats were they sell them.
#10 Re: how to combat axel trample
converted Posted on: 2005/7/1 2:42
yep 47312444 there are 30 years of development in these things
(1) 2 3 »
