Re: how to combat axel trample
From Brisbane, Australia
Andrew, are you using these springs unmodified? reay sway bar? are they the same springs as Craig? In the pics, your car looks much more stifly sprung.
Posted on: 2005/7/1 2:52
From Perth W.A
Does anyone know if they make a set for the 120Y coupe?
because i get axel tramp bad......
Posted on: 2005/7/1 3:06
120y Coupe
120Y coupe Race car (SOON)
120Y Sedan for the Lady
From Newscastle, Australia
Yeah Andrews have an extra leaf as opposed to mine due to the extra load on it. No rear sway bar on it. If the 1200 ones fit the 120Y then they should be interchangeable. If they dont swap over , John does not make them for a 120Y.
Posted on: 2005/7/1 3:24
Dont die wondering.....
120Y main leafs are longer. They are not interchangeable.
the number one cause of axle tramp is shagged shocks. if that's not the problem, just get another standard set of leafs from a wrecker, disassemble, cut the main leaf at the rear edge of where it sits under the diff and add it upside down to the front half of the top of your leaf pack. You'll also need to cut some off the front so it sits just behind the eye, but not touching. And round off the underside of those cut edges so they don't abrade the main leaf as they slide along it as the suspension travels.
Posted on: 2005/7/1 3:41
From Auburn, Washington
Get a B310. Voila! Axle tramp gone!
Posted on: 2005/7/1 4:30
From Perth W.A
Can anyone suggest any fixes for the KB210/120Y coupe, to remove axel tramp?
i have new good shocks in the back but all the suspension places i have tried won't reset my leaves in fear of breaking them. is there anything anyone can suggest?
Posted on: 2005/7/1 4:45
120y Coupe
yeah chowdozer voila!!! 200 extra kilos!!
Posted on: 2005/7/1 5:02
I take it you didn't like my suggestion?
what shocks do you have?
standard 120Y leaf springs?
lowering blocks?
Posted on: 2005/7/1 6:04
From Perth W.A
Sorry L18_B110 i didn't realise that post was aimed at me..... thought it was for the 1200 guys. i'll have to look into it.
I have KYB shocks from the front of a 94 hilux forerunner
in the rear and standard 120Y leaf springs, and no lowering blocks
Posted on: 2005/7/1 7:26
120y Coupe
From Brisbane, Narangba
Mine never really had a problem until I put in the new shocks and reset leaves (2" drop with extra leaf) and the got worse when I put the ute diff in. Its one of those hit and miss type thing though. Sometimes itll spin really clean and other times it will tramp. With an A-series powered car I dont think it is as much of a problem due to the lack of torque. A good launch can overcome the tramp. The other day it tramped in the wet third gear spinning at 5000rpm barely moving though. Rain makes the A-series equal to a CA that is in the dry.
Posted on: 2005/7/1 9:18
« 1 (2) 3 »
