« 1 2 (3)
Re: how to combat axel trample
From Mudgee NSW Australia
Harry I had to put an extra leaf in mine going from a series to CA18 it worked perfect with A series but with the torque of the CA it was turning them into a S bend
I dont run a rear sway bar the konis are set on medium. with the locker any harder and it oversteers its quite neutral as its is. As long as I dont feed to much power too soon its handling quite nicely. Believe it or not Im only running a stocko swaybar up front too the JTaylor struts and strutbrace do most the work I woudl like to get a bit more camber happening now its race only car 2.5 is ok but 4 would be better for track work.
Posted on: 2005/7/1 11:25
If In doubt run more BOOST
« 1 2 (3)
