Browsing this Thread:
1 Anonymous Users
Problems Getting my a12 going |
From Sacramento California
I'm having problems getting my a12 running. I'm running everything stock but I bought a weber 32/36. I'm running the jets suggested by a member on this site. I've changed all the ignition components and I've got a good amount of spark. fiireing order is correct.
The car fires but wont start. When it does fire it only putts a couple of times and spits fuel out of the air jets.
Not sure where to go from here any help would be greatly appreciated. thanks Max
Posted on: 2005/7/1 7:29
Re: Problems Getting my a12 going |
From Townsville NQ
Do you still have the original/previous carb to throw back on?
Has this problem only surfaced since changing the carb I mean, or has the engine never ran
Posted on: 2005/7/1 8:08
The car was not running when I bought it but it did run when I poored gas down the carb but it wouldn't idle. Anyway that was a while ago and after tinkering with the stock carb a little I couldn't even get it to do that anymore.
I took the carb apart in atempts to rebuild it but in doing so lost that little ball in the accel pump. Thats when I decided to go with the dgv.
Posted on: 2005/7/1 13:23
Not too shy to talk
From A
could be a fuel pump/line problem? Make sure they are both flowing
Posted on: 2005/7/1 14:18
Fuel is flowing really well all the way to the float bowl. No problems with the float mechanism eather seems to be working.
Posted on: 2005/7/2 1:10
