« 1 (2)
Re: retractable seatbelts for sedan
From Brisbane Australia
thanks dattodude, I had tried to fit a set that I had got from repco but they did not have the drop link.
Do you have the part no"s that you used ?
thanks ade
Posted on: 2005/6/19 2:05
From Sydney Australia
Thanks for the extra info dattodude ill try again when I get the chance...and yeah some repco stores are really crap.
Posted on: 2005/6/19 8:25
Currently own a 73 1200 with sr20de and a 71 1200 with almost finished a14 blow through
From sydney, australia
do you know if its the same setup for retractable seatbealts in the coupe cause i have no bolt in position for seatbealts on the door frame near the windows like you do in all modern cars.
My one has just a bolt on point behind the drivers seat below the rear quarter window an the belt comes around to the floor.
Posted on: 2005/6/19 8:44
From Sydney, Australia
Yes, I'm almost certain that these will also suit a coupe.
BTW. The drop links I used are 115mm long (not 150mm as previously quoted)
They were $44.30 each from my scratchy notes. This is what puts the cost up a little more obviously. This is on top of the $80 for the retractable unit.
Posted on: 2005/7/3 3:05
Dattodude can you take some photos of the droplinks and post them in this thread because the dodgey repco im dealing with now has 2 parts listed for the same part number. I have the retractable part already but I dont want to get the wrong droplink part, thanks heaps.
Posted on: 2005/7/4 12:48
I will endeavour to take photos this weekend. Possibly earlier, depending on Dyno availability.
Posted on: 2005/7/4 14:52
From Sydney.au
i bought two seatbelts for the front today (through Repco). i got the Klippan K1517 which isn't retractable. the buckle length bit (from where it bolts to the floor up to the level of the seat) was 30cm. i got non-retractable as the retractor thingy would be annoying and in the way for passengers (and my excess crap in the car).
Posted on: 2005/7/4 16:27
cheers dattodude
Posted on: 2005/7/5 9:16
« 1 (2)
