#1 Best Air tool to Cut metal
Demojob Posted on: 2005/7/4 12:47
hey guys,
I'm looking to do some fairly extensive cutting to the body of a car, whats the best air tool tool assist me? I've seen Air body saw's they look like a small recipricol saw, or then I've seen a nibbler (do they even cut?)
Cheers for any help
Damo
#2 Re: Best Air tool to Cut metal
731200 Posted on: 2005/7/4 12:55
I helped my mate cut the tunnel of his ute in about 20 minutes using an air hacksaw type thing, they go fast in a line but not so good for cutting round corners they just use a normal hacksaw blade and are bloody loud and aso go through a few blades.
#3 Re: Best Air tool to Cut metal
john_13961 Posted on: 2005/7/4 13:02
if u have a 4 inch grinder i dont think u can go past those tin cutoff blades i love em about 2 bucks each
#4 Re: Best Air tool to Cut metal
phunkdoktaspok Posted on: 2005/7/4 13:11
I use an air hacksaw also. I just use normal hacksaw blades cut down to size. The proper blades go to a point and are good for cutting corners, just like a jigsaw. I just use tin snips and cut the hacksaw blade just like a proper blade.
Best tool is a 1mm thick 4inch cutoff wheel fitted to a diegrinder or an anglegrinder.
Nibblers are good tools. Mad for cutting corrigated iron sheet. They cut a line and waste about 5mm of metal. Only problem is they are only good for cutting moveable sheet. ( basically needs to push one part of the metal away just like using tin snips except not so bad.) No good for cutting rust out of a panel. You would have to cut a big hole befor you could use the nibbler.
#5 Re: Best Air tool to Cut metal
kegs Posted on: 2005/7/4 13:12
u would be surprised how well nibbler's cut ive used em at tafe on sheet metal, maybe no good for tunnel as its a few layers, and is usually coveered in all sorts of #### like glue for carpet, sound deadener and tar on the bottom. a normal jigsaw is good i cut out a bonnet very easily.
