#1 Wanted- Front disk brakes
PHATDAT Posted on: 2005/7/6 12:44
I am after some complete front disk brakes/struts to suit my 1200 ute.
thanks
ps- or another way to put disks on the front with out to much hassels
cheers
#2 Re: Wanted- Front disk brakes
PIGDOG Posted on: 2005/7/6 13:17
where abouts are you
i have a complete 120y front end that will pretty much bolt straight in
but you also need the tandem master cylinder which i dont have
#3 Re: Wanted- Front disk brakes
PHATDAT Posted on: 2005/7/7 14:31
They in good cond? How hard would it be to get the other part? Dont want to buy something that i will have to F#*k around with for ages.
cheers Luke
#4 Re: Wanted- Front disk brakes
PIGDOG Posted on: 2005/7/7 14:44
once agian, where abouts are you
they are in reasonable condition, they stopped the 120y that they are in
i was told that a new master cylinder for a 1200 coupe(disc brake one) was about $110
its probably that easiest swap to get disc brake front, but most people go for the stanza swap as they have bigger brakes
all that you have to do is sort out new brake lines, there is more info on the swap in the tech section
#5 Re: Wanted- Front disk brakes
PHATDAT Posted on: 2005/7/7 17:45
im in mildura, how much you asking ?
#6 Re: Wanted- Front disk brakes
sidedraught Posted on: 2005/7/7 23:45
Luke put Mildura into your profile then it will come up under the picture of your car and you wont have people asking you all the time.
Then you are more likely to get responses from people with parts close to where you are.
#7 Re: Wanted- Front disk brakes
PIGDOG Posted on: 2005/7/8 5:22
i only want about $60 for the whole front end, its not like im going to use them
what every you think is a fair price
