L20b head on L16
From Bridgetown, Barbados. W.I
Anyone ever done this. The ports are f**king huge(found out 2day). Would the ports be to big for a L16 engine???
Posted on: 2005/7/11 2:04
Life's better SIDEWAYS!!
Re: L20b head on L16
The Combustion chamber for these heads is much larger, so you will get low compression ratios dependin on the head:
U67 - 7.8:1
v91 - 8.3:1
Not so good unless your going turbo.
Posted on: 2005/7/11 2:19
Its the U67 head.
Was planning on getting the cumbustion chamber welded up, to form a compact cumbustion chamber (jus enough room for the valves and spark plug)
Or is it better to jus port the L16 head?
Posted on: 2005/7/11 2:28
From Melbourne Vic
i once had a ported u67 head on an L18, but the bottom end used flat top oversized pistons to bump the compression back up. will the difference in piston size between the 1.6 and the 2 Lt make for a weird combustion area?
Posted on: 2005/7/11 3:25
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
can anyone answer the last question??
Is the dish in the L20b pistons the same as the L16??
Also wats the specs on the L16 and L20b standard camshafts??? tryin to find out which is better.
Posted on: 2005/7/22 16:04
Can only help you with the dish in the pistons
L16: -7.01
L18: -4.36
L20b: -11.36
also a good engine calc...
http://www.ozdat.com/ozdatonline/enginedesign/
May need to add some data in yourself though!
Posted on: 2005/7/23 6:42
so will the compression b around 8-8.3:1 with the U67 head on the L16??
Posted on: 2005/7/23 14:05
Can Soneone Please tell me The cc's of a U67 and W53 Combustion chambers???
thanks.
Posted on: 2005/7/31 22:46
What do u think?? Some ppl tell me they would be to big. Wat do u guys reckon??
The engine will be standard. CR raised to 10.5:1 and 40mm DHLA.
Posted on: 2005/7/31 22:51
