i am not supprise that the speaker dont sound as good in the factory location (the closer to you for midbass the better, i installed mine in the factory location but used plastic lik the
origanal to seal around and aflap over it to keep the water off, i also used sound deadener in the doors to help the midbass . also somthig you may like to know getting to the doors electric
windows are
p@#s easy to fit in to the doors (available at jaycar) whichy iseven easyer than cental locking which is damn easy in 1200 doors iknow im getting off the point ,but in such an old
car its so cheap and cool... getting back to the point though the best area to moun the tweeter 4 immiging is on eitherside of the dash . for the subs i know u want to mount them where the
tank is but the further back the more bass. 4 the 6 9s the factory shelf is the best but make a decent shelf using mdf, u are probably wanting tostill carry stuff in to boot with the subs but
all good things come at a comprimise and i would recomend if you are going to fang around or carry things around just take the subs out they only slow you down anyway and if ya wana boom
throw them in in there box with no comprimises and make your noise. you may find if you are using big subs the boot will rattle ,just put heaps of undrbdie tar under it and tighen the boot
down ,you may need to ut some rubber under it as chocks. these are my expereances and prefrences and should be regarded as only those.and im tired...yawn.. and i would be intrested in ANY
opinions or questions.
