Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#11
Re: A14 pistons/overbore etc
mperdue
Posted on: 2005/7/15 16:51
Thanks L18 but I've already got the pistons and am running out of time and money to keep returning new parts. I wish I'd known this a couple of weeks ago!!!
Here's my compression ratio calculation. I just took a guess on the space between the top of the piston and top of the block at 0.5cm. Original Pistons: 7.6 x 7.7cm => 349.3cc displacement per cylinder Compression Ratio = 8.5 displacement volume + combustion chamber volume = 8.5 x combustion chamber volume dv + ccv = 8.5ccv dv = 8.5ccv - ccv = 7.5ccv ccv = dv/7.5 = 46.6cc per cylinder original combustion chamber volume = 46.6cc New Pistons: 7.7 x 7.7cm = 358.5cc displacement per cylinder dish is approx 5.7cm across, .12cm deeper than stock added combustion chamber volume due to dish depth is 3.06cc Added bored area due to oversize = 1.21cm^2 (need to know space between top of piston and top of block to calculate added volume due to this area difference) WAG of 0.5cm space so bore volumem above piston = 0.61cc so new ccv (combustion chamber volume) is original ccv + deeper dish volume + added bore volume above piston 46.6cc + 3.06cc + 0.61cc = 50.27cc so new Compression Ratio = (50.27 + 358.5)/50.27 = 8.13 Ignoring that little volume (0.61cc) due to the space between the top of the piston and the block it would be around 8.22 That is way too low - I'd rather be closer to 9:1. Crap. You can view topic.
