« 1 (2) 3 »
Re: nissan 4cylinder engine with 8 spark plugs
From Perth
CA18eT also runs a SOHC 8 valve 8 plug arrangement
Posted on: 2005/7/16 8:32
From Alabama, U.S.A.
Here in the U.S.there was a Z-20 ,Z-22, and Z-24. The early ones had 4 plugs and then they went to 8 plugs a little later.
Posted on: 2005/7/16 17:07
From Bridgetown, Barbados. W.I
if its a Z22/Z24 it would be nice as i woould have free crank.
Posted on: 2005/7/16 17:30
Life's better SIDEWAYS!!
From Lethbridge, AB, Canada
If its a 1.8L or 2.0L then its almost for certain a CA18ET or a CA20E, becuase its rear wheel drive it would be out of a Nissan 200SX/Silvia/Gazelle (1984-88)
They are good engines, but depending on the year there are two different trannys.
The earlier had the B tranny and the later had the C tranny.
I dont know what application you need the transmission for but I can tell you that the C tranny will bolt up to a CA18DET motor.
Posted on: 2005/7/16 18:58
'73 Datsun 1200 Sedan Turbo A12
From Arlington, TX, USA
independentslider1 wrote:
on the tapic cover it has nissanZ
Did any of you guys read the original post?
If it says NissanZ on the valve cover, it's a Z18/Z20/Z22, not any sort of CA engine.
Posted on: 2005/7/17 17:07
1973 Datsun B110 Coupe (A15/5spd)
1977 Datsun 280Zed (5.0L/5spd)
Nissan4Eva wrote:
Hey wat about the engine???
R they any good???Better than a L20b??
Don't know about "better", but it is shorter, by at least 1". Good thing for a 1200...
Posted on: 2005/7/17 17:10
So r any Z parts inter-changable with the Lseries engines??
Posted on: 2005/7/17 23:21
Not too shy to talk
From Barbados
thanks
i plan to build a totally different l16 to use the 5speed box on
port and polish head
3/4 race cam
extractors
2 weber 45s
bore block to 85mm
people in barbados think i am wasting time with a l16 so i want to make them eat their words
so input on my plans are welcome
because i want to get best possible results
Posted on: 2005/7/18 14:26
Not too shy to talk
From Barbados
i also plan to get my crank knife edge
Posted on: 2005/7/18 14:40
when u ready to buy it let me know. if its a Z20 or Z24, i would help u buy it....cause i would want d rods
U going Bushy Park dis Weekend???? I feel i going tho......the LSeries Should be working by then if not the A12T.
Posted on: 2005/7/18 22:18
« 1 (2) 3 »
