Either Or...
From Bridgetown, Barbados. W.I
because of class regs....i can use a single 40mm weber to two 1 1/4 Su's which will give the most/better performance???
Posted on: 2005/7/18 19:37
Life's better SIDEWAYS!!
Re: Either Or...
From Adelaide, South Australia
You should know the answer to that, come on give yourself more credit than that.
Posted on: 2005/7/18 20:04
"Anyone who has never made a mistake has never tried anything new"
Albert Einstein
Put stupid oversized photo here>>
Re: Either Or...
yeah but i want other ppls opinions
Posted on: 2005/7/18 21:18
Re: Either Or...
From sydney
I will go with the weber because you have a greater potential airflow.
approx 1/4 inch larger per throat.
Posted on: 2005/7/18 23:09
Re: Either Or...
The weber throat size is 40mm
the SU's throat size is 31.75mm
So that = weber.
Posted on: 2005/7/19 22:18
Albert Einstein
Re: Either Or...
Not too shy to talk
From Barbados
well weber it is them
so i will let you get de one out de 1200 i buying
and i will get the one from shortman
Posted on: 2005/7/20 23:17
