#1 Either Or...
Nissan4Eva Posted on: 2005/7/18 19:37
because of class regs....i can use a single 40mm weber to two 1 1/4 Su's which will give the most/better performance???
#2 Re: Either Or...
killer1200 Posted on: 2005/7/18 20:04
You should know the answer to that, come on give yourself more credit than that.
#3 Re: Either Or...
Nissan4Eva Posted on: 2005/7/18 21:18
yeah but i want other ppls opinions
#4 Re: Either Or...
sidedraught Posted on: 2005/7/18 23:09
I will go with the weber because you have a greater potential airflow.
approx 1/4 inch larger per throat.
#5 Re: Either Or...
killer1200 Posted on: 2005/7/19 22:18
The weber throat size is 40mm
the SU's throat size is 31.75mm
So that = weber.
#6 Re: Either Or...
independentslider1 Posted on: 2005/7/20 23:17
well weber it is them
so i will let you get de one out de 1200 i buying
and i will get the one from shortman
