Re: raceday handeling success
From Newscastle, Australia
Sounds good, hopefullI have now fixed rear high speed grip with new car with 2 degrees neg camber in back axle housing.
A cheap method of doing this is to run a weld along the top of each side of the axle housing.When the weld cools it bends the axle housing and gives you negative camber in rear. All you need is approx 1 to 2 degrees
Posted on: 2005/7/24 21:29
Dont die wondering.....
Subject Poster Date
     raceday handeling success BigV 2005/7/24 10:19
       Re: raceday handeling success sunny 2005/7/24 13:22
         Re: raceday handeling success BigV 2005/7/24 16:51
           Re: raceday handeling success converted 2005/7/24 21:29
             Re: raceday handeling success BigV 2005/7/25 9:16
               Re: raceday handeling success converted 2005/7/25 10:55
                 Re: raceday handeling success Rallytwit 2005/7/25 20:04
                   Re: raceday handeling success BigV 2005/7/27 14:40
                     Re: raceday handeling success sunny 2005/7/27 16:54
