A14/15 engine conversion in a datsun sunny
From Brisbane
hey i was just wondering if either an A14 or A15 engine conversion was a good option, easy conversion, legal where i am (brisbane, AUSTRALIA), and cheap for my datsun sunny gl 1981 model????
ive had lots of other plans for my dato but ive decided 2 stick wif the A series engines :P
well any input.comments/advice wud b greatly appreciated
thanks,
maztec
Posted on: 2005/7/24 12:25
Re: A14/15 engine conversion in a datsun sunny
From Central Vic
just to help sunny wagons had A15's or A14's
grab a radiator out of an early gemi for a reasonable radiator up grade and bolt it all in its that simple
fit a two inch engine pipe and 1 3/4 system
and if your feeling realy keen bolt on a falcon weber and have loads of fun oh and run it on premiume with about 12 degres static timing
Posted on: 2005/7/24 16:57
From Brisbane
ahh ok then... ive got a sedan and its only got an A12 in it...... so im seriously looking to upgrade it.. im sure if the wagons had one in them the sedans could fit one in them...
Posted on: 2005/7/25 5:16
From Central Vic
yes ive done this conversions its not actually a conversion as far as im concerned
Posted on: 2005/7/25 9:10
From Brisbane, Narangba
Im in brissie to. It is the easiest conversion. Bolts in.
Posted on: 2005/7/25 13:08
From Brisbane
hell yea :D im guna do that then...... so its no hassles at all??? or jus need 2 change a few things????
Posted on: 2005/7/25 13:47
From T'ville
The hrdest part is finding a good A15/14 the rest is disconnect , unbolt , change engines
while you have the A12 out change the flywheel over , by running the A12 flywheel you dont have to change the throw-out bearing carrier( on the front of the gearbox)
Different thickness flywheels have a corresponding carrier I have found three different length carriers so far!
The A12 are slightly lighter as well which is a bonus.
Good luck
Posted on: 2005/7/26 3:06
From Brisbane
ahh ok then.... well thanks for the input people... ill start lookin for an A14 or A15 right away..... if i knew it was that easy i wuda been lookin earlier lol!
ill keep yas updated on my dato sunny..... (atm im fixin up the interior [black wif orange accessories and outlines], and sanding down the body redy to be painted an orange [yet to choose which orange], and also gotta get sum rust cut out and weld the hand brake back in)
thanks,
maztec
Posted on: 2005/7/27 10:51
Not too shy to talk
From Sydney, NSW, Australia
where do you look for an A14/A15? which cars did datsun/nissan decide to put them in for the aussie market?
Posted on: 2005/7/27 13:58
From Canberra, Australia
Can still sometimes get them from importers.
BUt I reckon the best way to get one would be to put an ad up on ozdat to say that you want one.
Or if one is on ozdat to buy that... probably the cheapest way at least... BUt then again... you dont know what you are getting.
Posted on: 2005/7/27 14:12
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
