Swaybar help
From Perth W.A
hey guys the coupe is at the pointy end of the conversion with a fun little busy bee taking place in a fortnight from fellow ozdatters but i need some help.
now some of you may remember i started an L18 conversion into my 120Y a long while back and was using the engine crossmember from a 180B and bolting it into my coupe, well it's in but when i put the sway bar onto the link pins they are puched back on a fair bit of an angle instead of sitting straight so does anyone have any ideas to solve this?
do i need to get a custom swaybar or can someone suggest a swaybar that will fit? the 180B one was out of the question and wont fit.....
Posted on: 2005/7/19 8:32
120y Coupe
120Y coupe Race car (SOON)
120Y Sedan for the Lady
Re: Swaybar help
From Perth W.A
Anyone? please
Posted on: 2005/7/21 6:16
120y Coupe
Re: Swaybar help
From Brisbane, Australia
the control arm should really be in the same place, not further forward as it seem to be for you got a pic so we can see whats going on?
Posted on: 2005/7/21 6:25
Re: Swaybar help
From Perth W.A
I'll get one tonight. and put it up tomorrow.....
Posted on: 2005/7/21 6:34
120y Coupe
Re: Swaybar help
From brisbane
It shouldn't be a drama mate. When I refitted my stock swaybar after the CA conversion I had the same issue. I showed my suspension guy and he wasn't worried at all. However, I'm getting a custom swaybar later this year for better sump clearance and I plan to have it made so that the links are upright again.
Matty
Posted on: 2005/7/21 10:09
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
Re: Swaybar help
From Perth W.A
Cheers matty that makes me feel a bit better, but i will do as you did and get my suspension guy to check it out.....
Posted on: 2005/7/22 2:25
120y Coupe
Re: Swaybar help
no pics?
I'd like to see what's going on. I've been trying to think back to my old 120Y, and I'm sure the 120Y bar bolted onto the 180B front end with the link pins straight - just like it was all meant to be there..
Posted on: 2005/7/22 13:54
Re: Swaybar help
From Perth W.A
Sorry man it's been my 21st all weekend so i've been drunk.....
Posted on: 2005/7/25 2:32
120y Coupe
Re: Swaybar help
From Perth W.A
Here is the pic of my swaybar you guys wanted.
Posted on: 2005/7/29 4:59
120y Coupe
Re: Swaybar help
From South Africa, Bloemfontein
There is definately something wrong here.
The piece where the red rubber is must sit straight.
Something I noticed.
The U-joint that is used to bolt the sway bar onto the body, I notice that it has a bolt coming from above and then a nut bolted onto that. As far as I know this must be a Bolt that is screwed into the body from the bottom using a socket.
Did you move the factory bolting location of the U joints?
Can this maybe cause this spacing problem?
Just trying to find out what can cause this.
Posted on: 2005/7/29 7:48
1977 Datsun 1200GX
(1) 2 3 »
