Browsing this Thread:
1 Anonymous Users
one A12 piston fireing wrong, please help |
Not too shy to talk
From Slovak Republic, Modra
I have problems solwing my 3 months misery. Piston #2 is fireing wrong. Looks like not permanentlyfireing or not getting fuel but other 3 pistons work perfect. Does not matter if engine is hot or cold, engine works #### the same way. The compression ratio is OK, spark is OK, I changed the distributor and cables. Other 3 pistong fire wonderful. What could be the cause?
3 months of trouble, please help. I do not want to pull out the whole engine out.
Posted on: 2005/7/30 10:31
Re: one A12 piston fireing wrong, please help |
From Brisbane, Narangba
U didnt mention spark plugs. Have you changed them?
Posted on: 2005/7/30 11:28
From Adelaide, South Australia
sounds like a plug to me change them around and see what happens.
Posted on: 2005/7/31 16:03
"Anyone who has never made a mistake has never tried anything new"
Albert Einstein
Put stupid oversized photo here>>
Quite a regular
From WI, United States
A new cap, rotor, and a set of NGK plugs would be a good place to start.
Posted on: 2005/8/11 3:00
Not too shy to talk
changed sparks, distributor, rotor cap, cables, adjusted timing, adjusted valves
still fireing wrong...
Posted on: 2005/12/12 11:44
From Brisbane, Australia
Does it sound better when the revs rise?
Does the plug in #2 look like it is running lean?
If so, I would look for vacuum leaks. Spray a bit of CRC/WD40/INOX around the manifold, if the idle changes, you are looking in the right spot.
I would suggest a cracked intake manifold or gasket.
Posted on: 2005/12/12 22:35
From Tamworth, NSW
hey have you had the head off may be you have a hot spot an causing pre ignition???/
Posted on: 2005/12/13 2:03
From Vancouver BC Canada
obviously you have 1243... right?
Posted on: 2005/12/13 9:32
Quote: If at first you don't succeed, lower your standards. Keith (Mac-Datty)
Not too shy to talk
Posted on: 2009/12/16 12:59
Not too shy to talk
Now I realize, I was driving more than 3 years with blown head gasket!!!!!!!!
LOL I posted this on 2005/6/7 23:40
DATSUN FOREVER!!!!!!!!!!!!!!!!!!! GREAT ENGINES!!!
Posted on: 2009/12/16 13:01
