1200 Ute Brakes
Quite a regular
From Whyalla
Hello I have 2 1200 utes 1 is 1980 model with front disc brakes and the other is a 1975 with front and rear drums. I would just like to know if its possible to swap all the disc brakes to the 1975 drum model?
what would I need to swap, master cylinder? front shocks and stub axels.. and would i need to change the rear wheel cylinders aswell?
The diff in the 1980 model is a borg warner type and the 1975 model is a banjo..
Any help would be great. thank you
Posted on: 2005/7/28 17:09
Re: 1200 Ute Brakes
Quite a regular
From Whyalla
so i gather no 1 here knows about swapping brakes??
Posted on: 2005/8/1 15:26
Re: 1200 Ute Brakes
From Bris-Vegas
Mate, I can't answer your question - Except to say that with time & know-how anything is possible.
There are some members here that could probably help, but for the meantime I suggest you try the search bar on the LH side of your screen........ Discussion threads on brakes are very common.
Posted on: 2005/8/1 23:21
CA18DET '74 1200 ute project
Re: 1200 Ute Brakes
From Brisbane Australia
The brakes will swap with no hassle, swap the whole strut assembly, with the master cylinder the later one should be a dual system this I think is better as you have a larger amount of brake fluid.
The wheel cylinders wont need to be swapped and the diffs should be the same but I cant remember the which is which
Ade
Posted on: 2005/8/2 8:00
