« 1 2 3 (4) 5 »
Re: help needed from the conversion experts
From Melbourne AUS
nah didnt try that...
i had a busy arvo but i managed to get it up on stands and dropped the gearbox oil...
tomorrow after work gonna rip it all apart...
good thing about the rotor is that there isnt much less room to work with than the a series engine...
taking the box out is very easy thank goodness for my sake
Posted on: 2005/8/1 13:53
1973 B110 A12
From Canberra
I hope this doesnt come back to bite me but if you tailshaft checks out OK and your uni's joints havent been fitted poorly then I would bet a six pack on it being the wrong pre load on the diff pinion bearing. I suggest whilst its all apart you take the time to have it checked by somebody that has a good understanding of diffs.
I suppose there are quite a few members that would like to know what is causing your vibration. Please tell us all when you eventually find it.
Posted on: 2005/8/2 1:05
Would not enough pre load on the pinion, show up as forwards and backwards movement in the pinion? Would it be noticable to the hand?
Was anything done to the diff before or during the conversion?
Posted on: 2005/8/2 8:32
From Melbourne AUS
nothing has been done to the diff before or during the conversion... apart from putting in some new oil..
when the old a12 was in there there was no vibration at all...
doesnt anyone think that the play in the output shaft slopping around could be my vibration?
Posted on: 2005/8/2 9:25
1973 B110 A12
nup
fare chance tho as you've tried the diff at different angles with no luck .... shame you've dropped the oil cos i still reckon the hose clamp on the tail shaft would have showed it up more ...
Posted on: 2005/8/2 9:38
From Perth Austarlia
"only when not under load..ie if you put the clutch in to change gear.. when accelerating theres no vibration... when coasting in gear theres no vibration.. only for a second when u let go of the accel pedal"
Hey phunks.....basic physics may work...but they need to apply to the problem...
The problem occurs when NOT under load...when the clutch is ENGAGED..
Phunks you may be onto something with the wheels...I spose when under load the "vibration zone" would be passed quite quickly and thus the vibration may be less obvious..I spose this could also explain why you may be right about the unis...
But with the unis...I understood you saying the angle is caused by axle wind up???..if this is your theory then I spose it can't be the unis...this time!!!! as the problem occurs under no load..
Posted on: 2005/8/2 12:49
From Canberra
I would have thought the same but I couldnt feel any play and finally put a dial indicator up to double check, axial play was only 0.002inch mixed with around 0.002inch lateral play. So not a great deal especially in a rally car but enough to cause a very similar vibration whilst on transport stages to what has already been described. I have mentioned this bit of preload advice because I believe it is often overlooked. Thats why it took me so long to eventually find the problem in my rally car. I am not saying that this must be the problem vibration we are all trying to solve but all the symptoms apear to be the same.
Posted on: 2005/8/2 14:14
From Melbourne AUS
the car was running prior to the conversion with standard running gear all fine and no vibrations...
wouldnt that rule out things like diff, wheels, wheel bearings etc etc?
the only things that have been replaced are motor, gearbox and tailshaft..
thats why im focusing on those 3 things..
and to add to that i know that the motor and gearbox were operational without vibration prior to putting them into my datto ute..
so there for the process of elimination tells me that the only suspect things are the tailshaft itself and the positioning of the motor/gearbox in my ute...
i have pulled the gearbox out... going to try and reduce the angle by getting the gearbox as high as i can... im gonna get the tailshaft balanced and try and source another gearbox to rule out that sloppy output shaft that im not happy with..
fingers crossed
Posted on: 2005/8/3 9:09
1973 B110 A12
i have a slight driveline vibration which only occurs above 60-70kph and only when not under load..ie if you put the clutch in to change gear.. when accelerating theres no vibration...
Datsik I believe you are reading it as "if you put the clutch in to change gear when accelerating theres no vibration."
It happens when under no load. Basically thats anything where the car isn't accelerating or maintaining a constant speed.
Tailshaft man says put box higher.
Raising the pinion angle will equal doing this.
Any forwards load will cause the pinion angle to raise. No load keeps the pinion angle down - this is where we have a vibration occuring.
Its only noticable from 60kph. Well we know how a vibration from a wheel comes and goes - this gives reasoning to why the vibration might not be evident below 60kph.
Do you think basic physics of 2 unis on a shaft might have relevance to this ? I do and judging by your comment below, so do you.
if it's when your coasting, it sounds like theres some slack somewhere, when you get on the gas the slack gets taken up.
I dont really think it would be out of ballance wheels. Ange said that when using spacers to angle the pinion, the vibration wasnt felt till round 80kph. That tells me that more upwards angle is required on the pinion.
1200coupe 0.002inch, I bet you were relieved when you finally found that. Bet the dial indicator was only brought out after every other 101 possible causes were checked.
Posted on: 2005/8/3 9:18
From Melbourne AUS
while i didnt have any special measuring tools.. i increased the pinion angle up in different amounts... the best result (not that is was a good one) ending up with a 5mm spacer in between the leafs and the front of the diff mounts..
the pinion angle was visually greater than the angle on the output shaft.. and yet the vibration was still there...
this is what has made me think the play in my output shaft doesnt agree with my angle... so trying another gearbox is what i plan to do but while it is out i might as well try to make more room to get the box higher... because once im done with the conversion i wish to lower the rear of the ute an inch which is going to make the angle greater again..
Posted on: 2005/8/3 9:40
1973 B110 A12
« 1 2 3 (4) 5 »
