work my A12 or buy a stock A14
From Brisbane
hey pple..... use hav helped me quite a bit so far.... but there is just one more thing.... im having a hard time deciding on wat i should do... i can either spend $600 (AU$) on working the A12 in my dato already (in working order) OR i cud buy a stock A14 for AU$600.... could use try and help me decide please??? will working the A12 be more powerful than the stock A14
p.s its only 600 i can spend
thanks
maztec
Posted on: 2005/8/5 11:05
Re: work my A12 or buy a stock A14
From Brisbane, Narangba
A14 is a better option due to the increase in size. It not only has more horsepower but also alot more torque which is essential especially in the sunny as its a heavier car. Dont spend $600 on a stocka. A fella on here a few months ago advertised a complete A14 including gearbox(and it already had some work) for $200. i know you may not get a deal like this again but just wait around and see. Dont work the a12 either without a rebuild otherwise you will run into troubles when you start to rev the hell out of it as its already worn.
Advise is to go A14/15 if you want it to go decent for less $$$. Put it this way a stock a14/15 will beat a mild a12 and still be easier to drive.
PS. I have an a14 short motor but would require new rings and possibly pistons. Its apart so you could check it out if you want.
Posted on: 2005/8/5 11:17
My ute has a very worked A12 in it, ground up with twin 38 webbers. It goes hard and sounds Very tough!
But it's had more then 600$ put into it thats for sure!
Posted on: 2005/8/5 11:19
From Brisbane
there is this guy near me sellin his A14.. its jus been reconditioned and its just got no carby.... it also comes wif the gear box... i was planning on buyin that one... but if you could do a better deal u may have a buyer
Posted on: 2005/8/5 11:20
$600 for a full reco is a pretty decent price. Mine is a complete A14 block with no head. $100 and its yours.
Posted on: 2005/8/5 12:21
From wellington N.Z
HOLD OUT MY MAN A DEAL WILL COME YOUR WAY SOONER THAN YOU THINK.
I SCORED AN A15 PLANED PORTED POLISHED DOUBLE SPRINGS BORED 2 1580 ETC 5 SPEED BOX OVERSIZE RADIATER, OIL CATCHER, TRANSISTER IGNITION, TWIN 40'S 32MM CHOKES 4 $650 WITH ONE YEARS DAILY DRIVING AND ON START UP IT SMOKES LESS THAN MY PREVIOUSLY OWNED RECONDITIONED STOCK A15 WHICH INCIDENTLY WAS AS FAST AS MY MATES TWIN 40ED 1200(1500HEAD). i'D NEVER GO BACK TO MY STOCK A15 it was good for what it was but but can't compare with what i'm runnin now. I reckon you should hold out for a deal or save your dollars, cause if you settle for less you'll just end up upgrading, unless your using it as a daily driver and fuel cost's are a factor.
Posted on: 2005/8/5 13:21
I'd wait for a better deal, and go with an A14 or A15, a weber/ford carb and 1.75 inch exhaust. If you put an A15 in your B110 or B310, be careful about the transmission. The 56-series tend to break behind A15s.
On the other hand, building up an A12 would be fun, but I don't think it will be faster (for $600).
Stock A14s go for $200 USD here ... and nobody buys them ...
Posted on: 2005/8/6 7:28
From penrith
i got an a15 twin carby 40mm webbers still in ute running $400 in sydney, 0422 521 574
bargain price perfect lil motor...
Posted on: 2005/8/6 10:43
From Lethbridge, AB, Canada
From a wreakers?
Did the A15 come in anything in north America?
Posted on: 2005/8/6 18:59
'73 Datsun 1200 Sedan Turbo A12
Yes, at the wreckers here in western Washington (Pacific Northwest).
A15s were quite common in B310 wagons, 1980-1982. Some of the KB310s also have A15s.
Posted on: 2005/8/7 6:55
