Re: L28B into sunny?
From Central Vic
Not into square headlight model
if you redrill the mounts that bolt to the block and choose the right engine mounts the rockercover just rubs as i said just
Posted on: 2005/8/7 10:46
From sydney australia
yes,i used redrilled stanza mounts,dropped the engine about 10 mm.i should have got the motor moved back about 5 mm as well,as the swaybar is rubbing on the front of the sump.i'll try fitting a stanza swaybar,but i'll probably get
another set of mounts redrilled anyway.my problem was i've got an l18,& the standard l series oil filter hit on the engine mount,so i got a stock a series oil filter,& it gave me enough clearance for the filter.
Posted on: 2005/8/8 2:34
« 1 (2)
