Re: Going to Swap Meet ??
From Canberra, Australia
I just got mine from Autobarn. Can you no longer get them from there anymore?
If you have the option get the one for flat searing wheels even if you are using the dished ones as it will mean that you wont be getting your finger caught on the indicator stalk when you turn corners.
Also if you need to bend the stack. Make sure that you only bend the stalk and not the bit at the end that changes between high and low beam and sometimes it means that it connects the two at the same time which blows your headlight fuse.
Quite annoying really. Happened to me and to my friend.
Posted on: 2002/9/1 7:38
Subject Poster Date
     Going to Swap Meet ?? amshaw 2002/9/1 2:29
       Re: Going to Swap Meet ?? Lobster 2002/9/1 7:38
         Re: Going to Swap Meet ?? amshaw 2002/9/1 9:58
           Re: Going to Swap Meet ?? go_the_datto 2002/9/1 12:19
             Re: Going to Swap Meet ?? amshaw 2002/9/2 6:04
