Tranny swap
Ok folks
Anyone out there know if a 5 speed tranny from an 81 210 1488 engine will bolt up to an 80 210 with a 12A engine. Thanks!!
Posted on: 2005/8/20 22:09
Re: Tranny swap
Sure will. All a-series engines use the same bellhousing bolt-pattern.
Posted on: 2005/8/21 1:59
Re: Tranny swap
thanks!
Posted on: 2005/8/21 3:01
Re: Tranny swap
From Burbank, CA
What about driveshaft splines?
I know the models that came with the 63a boxes use a larger spline than the 60 boxes.
Posted on: 2005/8/21 6:50
|||\ 81 KPB310 /|||
Re: Tranny swap
Good question. The B310s (as far as I know) only use 56-series or 60-series transmissions. The driveshafts I believe are the same, but there are two different style of tranmission crossmember mounts. The 63s came in the B210s.
Posted on: 2005/8/23 4:44
