Re: Release bearing issues
From sydney australia
easier way to get the throwout bearing closer to the pressure plate is to remove the 5 mm thick alloy plate,which is purely a cover to keep
rubbish out of the clutch assembly.you can get a half moon shaped plate from a sunny auto,which will bolt in,or use the stock 1200
one & just drill the holes out to 10 mm.this will also give a little more clearance around the transmission.
Posted on: 2005/8/24 8:43
From Christchurch. NZ
I don't remember seeing a 5mm alloy plate, Mine has a pressed steel one which would make 1 maybe 2mm difference.
Posted on: 2005/8/24 9:04
From Christchurch NZ
I thought that the sandwich plate was supposed to help spigot the startermotor in the right position. Whan I haven't used one the starter pinoin/ring gear mesh has sounded awful.
Posted on: 2005/8/25 11:00
Forced Induction!
I think you'ld be right And guess what, My ute goes HARD now
Posted on: 2005/8/25 11:05
From Taupo New Zealand
good on you Damon. Now bring it up north to Taupo's new circuit and we'll have a race!!!
Posted on: 2005/8/25 11:26
1970 1200 coupe A15
1972 1600 original except for nana's sheepskins
1978 B310 SR16VE
It breaks out in 3rd gear, So I think I would need a LSD before I took it racing
Posted on: 2005/8/25 11:28
« 1 (2)
