« 1 (2)
Re: CA18det ecu problems
From newcastle, NSW
do a cpu diagnostics test it is quite easy...
Did that, and the red LED flashed 5 times and then the green flashed 5 times, i'll check out that silvia site in a minute.
The thing is(as i said earlier)when i put it on the truck it was going, and when i took it off the truck(TNT)in newcastle it was dead, didn't fire at all, before i put on the truck it was working fine nothing wrong with it, i even raced at Mt cotton a couple weeks ago, it was fine until i put it on the TNT truck.
i also said earlier i found the connections to my stereo connected; (+)positive to (-)negative, i was speaking to a mate and he said that could have caused a power spike which could have stuffed the ecu.
thanks for all the help!
Posted on: 2005/8/25 8:55
From newcastle, NSW
going off what nissan silvia.comsaid the red LED's are worth 10 and the green LED's are worth 5
Therefore; my code is 505, and it's not listed.
does anyone have a listing of this????
Posted on: 2005/8/25 9:18
From Sydney, Australia
ns.com is not a reliable source of information.
EF-EC 72 : 5 red, 5 green is "ECCS Normal Operation".
Posted on: 2005/8/25 9:50
From Brissy
check if ur battery still has charge..
Posted on: 2005/8/25 12:29
From Warwick, QLD
pul out your CAS and turn your ignition to on and spin the CAS do you hear your injectors ticking??? if not then your ECU or power to your injectors are f'ed
If they click meaning they operate fine, then pull out a spark plug (after you've put your cas back in and having the spark plug still conected to the coil pack earth out the bottom of the plug to the engine body or head (anywhere that is metal) and tun over the engine see a spark???
basically one of those tests will tell you whats failing spark or fuel or both.
Then you can go off and check voltages on your ingition wire to the ECU etc,
have you checked your ignition relay??? is it still working or has come loose??? check you fuses in your fuse box haven't come loose in trasit.
Posted on: 2005/8/25 12:35
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
From brisbane
Hi Steveo - Red LED's are worth 10 and the green ones are worth 1. 55 means it's all good.
Matty
Posted on: 2005/8/25 16:53
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
« 1 (2)
