Re: Diff to suite Datsun 1000
From The Dat Cave.
If you read the relevant posts on this site you will find that the 1200 ute uses an H165 dif [which will not fit your H145 housing]
The 1000 car models also used 4.11 to 1 ratio's in their H145 diff which is a lower ratio than 3.9.
The 120Y & Sunny used a H150 diff of 3.9 ratio which will fit in your H145 axle housing with another gasket and a spacer.
The diferential from a very late sunny wagon that came with the a15 engine is 3.7 ratio and the 3.54 ratio was not used here, so you need to get one from overseas.
Bigger diameter rear tyres will help.
Posted on: 2005/8/27 6:52
Subject Poster Date
     Diff to suite Datsun 1000 s13drifter 2005/8/22 14:08
       Re: Diff to suite Datsun 1000 Dats-hot 2005/8/22 15:42
       Re: Diff to suite Datsun 1000 s13drifter 2005/8/27 5:45
         Re: Diff to suite Datsun 1000 Dats-hot 2005/8/27 6:52
