Re: hi guys
From Perth Western Australia
yes they do. I have one in my 1200 ute. I think you have to weld up some brackets for the handbrake, and posiibly some new mounts onto the diff ( I didn't do the conversion myself)
The track width is increased by 20mm or something with this diff, but if you have 120y or stanza struts, it'll be about right.
I take it by your username that you have a CA18det. if its mild, you can use a 1200 ute diff. apparently they can handle (mild only) ca's. If its worked, the 120y diff won't hold on a lot longer, but i think they are slightly stronger.
Posted on: 2005/8/30 4:16
Subject Poster Date
     hi guys aca18turbo 2005/8/30 4:05
       Re: hi guys dazzasute 2005/8/30 4:16
         Re: hi guys sidedraught 2005/8/30 7:52
       Re: hi guys short_coupe 2005/8/30 7:56
         Re: hi guys aca18turbo 2005/8/31 13:31
           Re: hi guys ddgonzal 2005/9/2 4:30
