« 1 (2)
Re: need help on taking out 120y (B310) meter panel
hahaha
mine also got small cracke there
and the meter clear plastic like have 'haze' (not dust)
must be the hot weather here.. :)
Posted on: 2005/8/30 6:03
From sydney australia
the two screws under the dash panel are a little way back.one holds the metal bracket the choke cable goes through,the other is very close to the drivers door,on a little extension
which is very easy to break if you don't find it.the best way to see this one is to get on your knees just outside the drivers door & look up at the underside of the panel between the door & the steering wheel.running your fingers along the inderside will also show you where it is.
Posted on: 2005/8/30 7:34
oic.. like that
let me go find later
thanks a lot for helping me out there.. :)
Posted on: 2005/8/30 8:57
« 1 (2)
