A15 no power at 5000rpm
Quite a regular
From South-Africa Pretoria
Hi got a A15 motor,i fittet a new carbie,at 5000rpm i lose alot of power,it was the same with the old carb. Could it be my elec fuel pump? It use to be fine,
Posted on: 2005/9/4 0:48
Re: A15 no power at 5000rpm
From Christchurch. NZ
Check you points, maybe?? or you could be right.
Posted on: 2005/9/4 1:11
Quite a regular
Thanx I will do that,maybe it could be the fuel filter aswel, You dont think it could be valves?? I realy hope not! . The pump is about 10years now... Wil it work if I put a inline fuel pump in that pumps constantly,the carb is a hitatche,it wont flood wil it? The other pump got a presure swith.
Posted on: 2005/9/4 1:47
From Christchurch NZ
I'd say points too.
Posted on: 2005/9/4 9:02
Forced Induction!
Quite a regular
Thanx,i wil check the points then,
Posted on: 2005/9/4 11:48
Quite a regular
THANX for the advice,it was in fact the points!!
Posted on: 2005/9/4 14:10
hi all..
sorry i am newbie..
what is 'points' means?
hope someone can teach me
actually i just swapped my A12 to A15
and i feel that not much power different also.. :(
maybe something wrong..
Posted on: 2005/9/5 9:26
What do I win?
Posted on: 2005/9/5 9:53
Forced Induction!
From Sydney.au
sam1741 you can ask any mechanic but 'points' or 'contact points' is a bit inside an old (pre 1980's) distributor. if you are looking for performance out of your a15 is to get your hands on a fully electronic distributor or upgrade your contact points to a contactless system using a hall effect sensor. you can always cheaply replace your points from a car-shop but you should get a tuner to install and tune them for you.
goodluck and please use the search function, theres loads of info on ignition electrics if you just search for it. when i changed to an a15 i got a buttload more torque.
Posted on: 2005/9/5 10:15
Quite a regular
dont know? But thanx anyway!!! I Have a A12 engine for spares,but I am is SA!
Posted on: 2005/9/5 21:19
