#1 Nissan A15 motor specs?
CCG Posted on: 2005/9/6 22:40
Hi I have a stock A15 motor in my 120y ute,got a stock hitatce carb A14 and a stock cam,just wondering wat is the best timing for the motor 7deg,10deg? What should the dwel or point gap be? 0.40mm,0,45mm. Could anyone please help me? Thanx CCG
#2 Re: Nissan A15 motor specs?
COUP1200 Posted on: 2005/9/7 0:24
7-10 deg should be fine for the timing.
You are wright with the dwell settings.
The best way to set the dwell is with a meter at about 49-52deg. That is the angle on the distributor cam where the points open.
#3 Re: Nissan A15 motor specs?
CCG Posted on: 2005/9/7 15:00
Thank you!,Its set on 10deg and she is running good!
